Suggestions for gluing a plate http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=54012 |
Author: | bcombs510 [ Sat Mar 13, 2021 1:29 pm ] |
Post subject: | Suggestions for gluing a plate |
Hello, A couple weeks back I accidentally knocked over a sheet of plywood in the shop. The plywood knocked this plate off the bench and, ala Rube Goldberg, a large bottle of titebond rolled off the bench onto it, snapping it in half. It closes up nicely but I’m not sure how to clamp it. Maybe just the tape method? Any other suggestions? I tried to fit it into an LMI plate joining jig but it doesn’t line up well because it’s already trimmed to 00 shape. ![]() Brad Sent from my iPhone using Tapatalk Pro |
Author: | John Arnold [ Sat Mar 13, 2021 1:48 pm ] |
Post subject: | Re: Suggestions for gluing a plate |
Tape it. If I need extra clamping pressure, I use long strips of tape, stretching it over the edges. Sent from my SM-G950U1 using Tapatalk |
Author: | wbergman [ Sat Mar 13, 2021 2:11 pm ] |
My two cents. If you decide to wrap extra tape, rope, clamp, etc. then support the pieces with some cross boards so they do not buckle. You might also want to consider interior reinforcement across the repair, though if the glue joint is perfect, that might be superfluous. I am not sure if even the tape is useful, because with the kind of joining where you need each little irregularity to fit, the tape might interfere. Maybe just glue and leave it on the table. When I do that, I cover the exposed side of the joint with wax paper, so there is no differential drying to buckle the wood. I do not know if your wood would stain from CA. I have glued BRW top and back by laying them on the table on wax paper, fitting the pieces tightly, then flooding repeatedly with thin CA several hours apart. From tests, I found that a single flooding was all soaked up and did not glue the joint. |
Author: | bcombs510 [ Sat Mar 13, 2021 2:30 pm ] |
Thanks both! Tape seemed to work well, I got squeeze out all along the joint. I clamped it up between two pieces of plywood. I even got to use my Jesus take the wheel clamps. I haven’t used those in a while. ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk Pro |
Author: | Jim Watts [ Sat Mar 13, 2021 3:57 pm ] |
That's a bad omen when glue breaks it! I'd throw that glue away. Glad you got it fixed. |
Author: | Bryan Bear [ Sat Mar 13, 2021 3:58 pm ] |
I’d like to see what a Jesus take the wheel clamp looks like. |
Author: | bcombs510 [ Sat Mar 13, 2021 4:40 pm ] |
Bryan Bear wrote: I’d like to see what a Jesus take the wheel clamp looks like. Haha, its really any clamp you can use one handed, but I was referring to these: ![]() ![]() Brad Sent from my iPhone using Tapatalk Pro |
Author: | Darrel Friesen [ Sat Mar 13, 2021 6:46 pm ] |
Jim Watts wrote: That's a bad omen when glue breaks it! I'd throw that glue away. Glad you got it fixed. Ha! Love it. |
Author: | wbergman [ Sat Mar 13, 2021 6:54 pm ] |
By the way, what species of wood? |
Author: | bcombs510 [ Sat Mar 13, 2021 7:44 pm ] |
wbergman wrote: By the way, what species of wood? Black walnut from Ohio. I got two sets of it from American Tonewood. The sets were so thick I had half a mind to resaw the two into four. ![]() Sent from my iPhone using Tapatalk Pro |
Author: | bcombs510 [ Sun Mar 14, 2021 8:39 am ] |
Appreciate the help. It’s nearly invisible with the exception of a small area where a splinter was lost. I tried to find it when it happened, but no dice. ![]() ![]() ![]() Brad Sent from my iPhone using Tapatalk Pro |
Author: | wbergman [ Sun Mar 14, 2021 8:53 am ] |
Make a splinter from scrap. Doesn't matter if it is high--that can be leveled easily. |
Author: | James Orr [ Sun Mar 14, 2021 10:23 am ] |
Great fix! I just saw the thread, but I was thinking tape, too. I’m glad it did the trick! Sent from my iPhone using Tapatalk |
